Imaging (sensors)
Discuss applications using ST FlightSense Time-of-Flight sensors, ST BrightSense CMOS image sensors, and ambiant light sensors (ALS) technology. Find answers to your questions on troubleshooting, data accuracy, optimizing communication and more.
Reliability for VL53L0CX
Hello, I'm using VL53L0CXV0DH/1 within the construction of a more global solution and would like to have information about its reliability.Can you please help provide reliability information like Failure rate, Lifetime, MTBF, Warranty for the product...
GDjam.1 by Associate
  • 1429 Views
  • 1 replies
Resolved! VL53L3CX XSHUT PIN PROBLEM IN DEEP SLEEP
I have project using a VL53L3CX distance sensor. Also , I control it by ESP32. In normally, I can command to XSHUT pin. And I can read xshut pin of ESP32 that is 3V3 or 0V.But, When ESP32 enters deep-sleep mode for current consumption, XSHUT pin of t...
fafeyto by Associate II
  • 1658 Views
  • 1 replies
VL53L0X_GetInterruptMaskStatus fails
We are trying to get a VL53L0X sensor to run but VL53L0X_GetInterruptMaskStatus() constantly fails and we cant perform any measurements. We compiled the API provided by ST provided from https://www.st.com/en/imaging-and-photonics-solutions/vl53l0x.ht...
MMeng.3 by Associate II
  • 1335 Views
  • 1 replies
VL53L1 Question
Hello.​I2C frequency used by GUI for X-NUCLEO-53L1A2?Can you provide the firmware source used by the GUI for X-NUCLEO-53L1A2?When using the Raning mode of STSW-IMG019 (API for VL53L1CB), is there a minimum requirement for MCU memory, ram, and clock s...
joh.5 by Associate II
  • 1547 Views
  • 1 replies
VL53L1 and VL53L1X Timeing budget
hello.I'm testing the VL53L1 and VL53L1X.When the ambient light is strong, status = 7 is returned.​When the ambient light is strong, how should the timing budget and inter measurement period be set to measure longer distances?​Is it better to acquire...
  • 1372 Views
  • 1 replies
VL53L5CX maximum range distance?
Hi,I have some questions about the VL53L5CX maximum range. I am trying to reliably detect an oxygen cylinder passing through a portal 1200mm by 2133mm (floor level). The sensor is mounted at the top of the portal. I can detect cylinder up to approx. ...
MSwan.2 by Associate
  • 1671 Views
  • 1 replies
