GNSS positioning
Ask questions and find answers on Teseo GNSS positioning solutions. Discuss NMEA sentences, SBAS activation, and signal troubleshooting.
UM2229 Rev 4 missing details
HI,in UM2229 rev4 bottom of page 86/239 it seem value are missing in front of decription "Constellation disabled, Constellation satellites only tracked, Satellites constellation used in position evaluation"
Xynium by Associate III
  • 1187 Views
  • 1 kudos
Resolved! Teseo-LIV3 without antenna?
Hi..I have soldered a Teseo-LIV3 on a PCB with acces to power and RX/TX and nothing more. I read the NMEA strings, but no satellite data is present.Is it correct understood that Teseo-LIV3 can not operate without an external antenna? If so.....what d...
KMetz.1 by Associate
  • 2415 Views
Hey guys, I have been trying to setup X-NUCLEO with an stm32h743 Nucleo board using the "Application note" file but I could not update my STM32-NUCLEO board for X-NUCLEO-GNSS because the panel did not have a proper firmware.
I was looking to send instructions to X-NUCLEO using I2C , especifically the GetPos_I2C example but I dont know how set X-NUCLEO bord to recieve I2C instructions without the teseo-suite firmware. I was wondering if someone could help me with thatAppl...
Resolved! TESEO LIV3F No GPS coordinate
Hi, I am trying to get GPS coordinate with my PCB, which has just TESEO LIV3F. I connect the RX and TX of the TESEO LIV3F to RX,TX of arduino uno. I can see the NMEA information in my serial port put i couldn't get any GPS coordinate. I have attached...
AAl S.1 by Associate II
  • 2783 Views
  • 4 replies
TESEO-Liv3f manufacturer issue
Hi, I bought TESEO-Liv3f  module from mouser. when i made the PCB i was not able to get NMEA information and not even GPS coordinate. I checked if there is connectivity in my board and found out there is connectivity between RX and GND. I tried anoth...
  • 1706 Views
