2020-10-12 4:04 PM
2020-10-12 4:56 PM
Doesn't it provide detail via either the Talker ID or the SV numbering?
2020-10-13 12:54 AM
Hi
You should enable it in the message-list.
The following script will enable the message GST and save the configuration.
$PSTMSETPAR,1201,0x8,1
$PSTMSAVEPAR
$PSTMSRR
Francesco
2020-10-13 4:55 AM
I already have GST in the nmea list.
I mean i want a gst report for each constellation in use (residue or error)
I got GPGST but i suppose this error evaluation (noise) is not made only for GPS
I should have a GLGST and a GAGST
JP
2020-10-13 7:52 AM
Hi
In the Teseo3 solution (ICs and Modules) 'GPGST' you will always get 'GP' prefix whatever the constellations enabled because the reported values are related to the unique PVT solution.
Francesco
2020-10-13 9:28 AM
Ok
