GNSS positioning
Ask questions and find answers on Teseo GNSS positioning solutions. Discuss NMEA sentences, SBAS activation, and signal troubleshooting.
Teseo LIV3F Configuration over I2C Issue
I want to use the teseo LIV3f GNSS module as an I2C positioning sensor and i am following the AN5203. However, when i send the configuration over I2C, the GNSS module responds to all the commands with corresponding OK message except for the $PSTMSAVE...
VShen.1 by Associate
  • 1133 Views
  • 0 replies
TESEO VIC3DA UART2 communication
Hi, I am trying to communicate with Teseo module UART2 pins on the TESEO VIC3DA EVB via STM32F407 eval board UART pins. But not manage to send NMEA command and not get reponse NMEA message from the module . Here is the setup: Hard-wired STM3...
Spına.1 by Associate
  • 1636 Views
Disabling 2D fix on TESEO LIV3F
Hi Everyone, I am pretty new to working with a GNSS so please excuse my ignorance on some of these topics.I have been trying to find ways to check if I have a 3D fix or not so I tried to do this by disabling the 2D fix on "CDB-ID 222 – LMS operating ...
DN_1 by Associate II
  • 1895 Views
Cannot enable the autonomous STAGPS engine on TESEO-LIV3R
I have a Teseo LIV3R on a breakout board connected (via UART) to Tesio Suite. I'm trying to figure out how to enable STAGPS and test its functionality. Unfortunately I cannot enable the autonomous STAGPS engine using the command:$PSTMSTAGPSONOFF,1Whe...
MPete.5 by Associate II
  • 1871 Views
Resolved! TESEO VIC3DA application support
Hi, I have TESEO VIC3DA Evaluation board. I can not find this board schematics and other design files in ST website. I dismantle the box and look the eval board pcb and I saw there is STM32L4xx MCU. Here is my questions:We send the NMEA commands with...
  • 3557 Views
  • 3 replies
Teseo LIV3R Source Code problem on Android9 system.
Good afternoon. I bought myself Teseo LIV3R and LIV3F modules. Download the HAL library and errors are generated when compiling the kernel:hardware/amlogic/stm/teseo/libteseo.utils/../include/teseo/utils/Signal.h:300:35: error: unused parameter 'args...
NAvil.1 by Associate
  • 1442 Views
Why am I not getting a DR fix?
Hello,I'm currently using Teseo-VIC3DA Evaluation Board. I managed to get a 3D fix outdoors using DGPS. Afterwards, if I move indoors I get a "no fix" and I stop getting a position. Instead of this behaviour I would expect it would get into DR mode a...
HCabr.1 by Associate
  • 1071 Views
