Automotive MCUs
Ask questions and find answers on automotive microcontrollers like the SPC58 and their tools, such as the SPC5 Studio and how to implement JTAG unlocking.
Resolved! How to install your Root Certificate in StellarStudio JRE
When installing some StellarStudio  plugins http://*.srxstudio.org , you can meet the issue : sun.security.validator.ValidatorException: PKIX path building failed  It is typical IT Issue :face_screaming_in_fear:  in each corporate company. “"Path bui...
StellarStudio SR5E1 support is open to the mass market !
Dear all,   We are thrilled to announce that as of today, March 1st, 2024, SR5E1 device support in StellarStudio is available to the mass market !   This means that any user can effortlessly download the official StellarStudio installation packag...
Resolved! Regarding Flashing code to SPC560P - Discovery Board
Hi Every one, we are working on the SPC560P - DISP Board yesterday only we get the Board ,Now we are trying to Flashing the Board using on board flasher USB cable in that we get some error in the SPC5 studio so please can anyone know how to solve thi...
SPC58: Is there a way to know if UART has started a reception?
I am implementing a semi-duplex multimaster communication (based on RS-485), so before start sending message I need to know if any other node isn't transmitting anything. As far as I see the first information about any received transmission is UARTSR...
Yannek by Associate III
  • 5664 Views
  • 10 replies
Resolved! Compiler variant Error in SPC5Studio
Hello. I'va a problem in loading spc5studio samples. The error is:Problem opening file: 'L/spc560bcxx ee test application/configuration.xml': /spc5-config/application/instances/instance[1]​/build_setting/compiler_variant:'ppc-freevle-eabi-' is not a ...
Star one by Associate II
  • 1561 Views
  • 1 replies
Resolved! Application note for M3 xLoader and xFlasher
Where can I get a reference application note or user manual about M3 xLoader and xFlasher from STMicro?I am using Telemaco 3P and am interested in implementing a solution for reprogramming over UART.
SMeht.2 by Associate
  • 1446 Views
  • 1 replies
Resolved! How to get SPC5-CRYP-LIB?
I would like to get the SPC5-CRYP-LIB, but cannot find the access to download or request a invoice, so is there any solutions to get that library?
KYang.8 by Associate
  • 1393 Views
  • 1 replies
Resolved! SPC5Studio 6.0 - make not found in PATH
First time building a sample project after installation of SPC5Studio 6.0 + autodevkit + MCTK_LIB and got this:22:10:13 **** Incremental Build of configuration Default for project SPC560Pxx_RLA AEK_MOT_3P99081_3Phase_Motor_Control_via_CAN ****make al...
Rassom by Associate II
  • 2798 Views
Resolved! The PIT_0 timer interrupt is triggered only once after the reset and then not anymore. How to ensure that the timer retriggers every milisecond or second?
I am trying to use the example created by the SPC5 studio with interrupts. It has a PIT_0 (vector 227) configured. What i observed is that the interrupt is triggered only once after the application starts and is not triggered any more. As far as I un...
FShak.2 by Associate
  • 1951 Views
