2019-04-15 5:45 AM
Hello. I'va a problem in loading spc5studio samples. The error is:
Problem opening file: 'L/spc560bcxx ee test application/configuration.xml': /spc5-config/application/instances/instance[1]/build_setting/compiler_variant:'ppc-freevle-eabi-' is not a valid value for property 'compiler variant' .
How can I solve the problem?
Thanks.
2021-11-18 2:43 AM
Please use the latest Spc5Studio version, this issue has been solved.
Best Regards,
2021-11-18 2:43 AM
Best Regards,
