STM32G030F6P6 can't programming
buccno
I can control the card with stm32 CubeProgrammer when I reset mode "hardware reset". But when I use cubeIDE, I can't assign the program, it can't see the target, what could be the reason? Can I only use it in Hex mode?
Looks to be working
The "Programming" / "Downloading" is the second icon down on the left edge
Then you can specify your .HEX .ELF or .BIN file and program / verify from there.
Perhaps review a manual, videos or tutorials
3 REPLIES 3
buccno
with stm32 cubeprogrammer
Looks to be working
Semer CHERNI
Hello @buccno​
Did the proposed solution came to help?
Kind regards,
Semer.
