STM32Cube Programmer installation error
Soner23
Stm32cubeprogrammer installation does not proceed to the final stage, it remains at step 8 and is not completed. I tried the program on three different PCs with administrator rights, the result is the same, the installation does not complete.
Soner23
Hello @Aziz BRIGUI
Let me share an update on the issue.
I tried to make a fresh installation with English (USA) Language Windows 11 and install the program, it was installed without any problems.
My computer's language is Turkish, I added an English language pack to this computer, then I tried the installation again and it was installed without any problems.
Turkish I cannot complete the installation with Windows 11 and Windows 10. I hope you can solve this problem as soon as possible.
22 REPLIES 22
Which version?
What version of Windows?
Blocked by AV software?
Which version?
2.16.0 64 bit and 2.15.0 64 bit
Windows 11pro  23H2
No, the antivirus did not block it, but I will turn it off and try again.
gvelf
I have the problem with installation under Win7-64 ultimate, after installing it didn't work- may be because of Micro not support Win7?
Using Win7 here, that's not the problem.
Unfortunately "doesn't work" isn't a helpful diagnostic observation.
gvelf
I've reinstalled the app some times, but the same error appeared again.
Soner23
I tried to reinstall the program after formatting, the result remains the same at step 8 and the installation is not completed. Note do not install any anti virus software.
Pavel A.
Evangelist III
Unfortunately Windows 7 is not as alive now as it used to be.... to say it mildly.
Look in the installation directory. If the binary files are already there, you can kill the installer and just run the CubeProgrammer from the install directory or create a shortcut manually.
FatihGunes
We have the same problem. Tried on many computers. No luck. Anybody solved this problem on Windows?
Soner23
@Pavel A. @FatihGunes
Yes, I am aware of this, the program runs from the directory even if the installation is not completed.
What I'm curious about is that I always encounter the same error when I try it with different versions and different computers, or that many people experience this situation but the problem cannot be solved.
