Programming to external flash on STM32U5A9J-DK fails after around 2.5 MByte. How to fix this?
‎2023-05-31 06:22 AM
I'm using a STM32U5A9J-DK with TouchGFX. Smaller projects work just fine. But aufter integrating an Animated Image (approx. 37 MBytes of assets), the programming fails. The console log is as follows:
STMicroelectronics ST-LINK GDB server. Version 7.3.0
Copyright (c) 2023, STMicroelectronics. All rights reserved.
Starting server with the following options:
Persistent Mode : Disabled
Logging Level : 1
Listen Port Number : 61234
Status Refresh Delay : 15s
Verbose Mode : Disabled
SWD Debug : Enabled
InitWhile : Enabled
Waiting for debugger connection...
Debugger connected
Debugger connected
STM32CubeProgrammer v2.13.0
Log output file: ******************************
ST-LINK SN : ******************************
ST-LINK FW : V3J11M3
Board : STM32U5A9J-DK
Voltage : 1.79V
Error: No STM32 target found! If your product embeds Debug Authentication, please perform a discovery using Debug Authentication
2nd connect tentative with frequency (8MHz)
Voltage : 1.79V
SWD freq : 8000 KHz
Connect mode: Under Reset
Reset mode : Hardware reset
Device ID : 0x481
Revision ID : Rev C
Device name : STM32U5xx
Flash size : 4 MBytes (default)
Device type : MCU
Device CPU : Cortex-M33
BL Version : 0x92
Debug in Low Power mode enabled
Choose flashing speed for Cortex M33 series.(default speed=Reliable)
Memory Programming ...
Opening and parsing file: ST-LINK_GDB_server_a17156.srec
File : ST-LINK_GDB_server_a17156.srec
Address : 0x08000000
Erasing internal memory sectors [0 38]
Erasing memory corresponding to segment 1:
Erasing external memory sectors [0 591]
Download in Progress:
Error: failed to download Segment[1]
Error: failed to download the File
Encountered Error when opening C:\ST\STM32CubeIDE_1.12.0\STM32CubeIDE\plugins\com.st.stm32cube.ide.mcu.externaltools.cubeprogrammer.win32_2.0.600.202301161003\tools\bin\STM32_Programmer_CLI.exe
Error in STM32CubeProgrammer
Shutting down...
Exit.
In the debug configuration, following external loader is specified:
MX25LM51245G_STM32U599J-DK.stldr
I tried to read out the memory using a J-Link with the JMem tool. There, I noticed, that after around 2.5 MByte, the content is filled with FFFF... The external flash should have 64 MByte.
Is there a way to fix this issue?
Flash
STM32CubeProgrammer
STM32U5 Series
‎2023-06-01 07:36 AM
I tried version 2.10 of the STM32CubeProgrammer, which worked now.
‎2023-05-31 06:38 AM
The memory location, where it stops flashing, is always the same (0x9026 BC00).
‎2023-06-01 12:49 AM
Hello @JWill.11​ ,
Thank you for reporting this issue.
I confirm the issue: External memory programming failed using a file with size bigger than 2.4MB using STM32CubeProgrammer v2.13.0.
Internal ticket number: 147448 (This is an internal tracking number and is not accessible or usable by customers).
Kaouthar
‎2023-06-01 03:46 AM
Hi @JWill.11​ ,
Waiting for the next STM32Cubeprogrammer release, could you please use the STM32CubeProgrammer v2.12.0 version and check if the issue is solved.
I hope this help you!
Kaouthar
‎2023-06-01 07:10 AM
Thanks. Can you provide me with a link to this version, as through the official ST page, one can't download version 2.11 and 2.12.
‎2023-06-01 09:44 AM
Hi @JWill.11​ ,
Glad to know that the issue is already fixed.
I will let you know when the issue is fixed in the next version.
Sorry for this inconvenience.
Kaouthar
‎2023-07-11 08:43 AM
https://community.st.com/t5/stm32cubeprogrammer-mcu/stm32cubeprogrammer-2-14-0-released/td-p/573439
‎2023-07-23 08:25 PM
I use TouchGFX 4.22.0 to generate the UI code, use STM32CubeIDE 1.13.0 STM32CubeProgrammer v2.14.0 to flash my program into STM32u5a9j-dk, the issue still exists.
‎2023-07-24 04:02 AM
How did you switch back to STM32CubeProgrammer v2.10 from v2.13? Thanks.
