In STM32 Cube Programmer Unable to open file other options are working. Installed the latest version and restarted the systema s well. How to overcom this issue
Snara.21
11 REPLIES 11
Snara.21
@Houda GHABRI​  Is the information is sufficient or require more info. Kindly please let me know
Houda GHABRI
Hello @Snara.2​ ,
Thanks for your feedback.
Let me sure that I well understand the issue, so you are able to connect correctly, reading data correctly but when you click on "open file" CubeProgrammer hangs and no response?
Houda
