In STM32 Cube Programmer Unable to open file other options are working. Installed the latest version and restarted the systema s well. How to overcom this issue
Snara.21
Senior
11 REPLIES 11
Why can't you open a file? What happens when you try to do so?
Snara.21
Senior
It was working fine for past 4 months yesterday if I click open file no response. So I uninstalled , rebooted the system and downloaded the new version and rebooted the system still the problem persist
Houda GHABRI
Hi @Snara.2​
Can you please send the log file with verbosity 3 ?
Houda
Snara.21
Senior
How to do ? Sorry Verbosity is a software?
Houda GHABRI
Hi @Snara.2​
We can select different level of details for logfile generated by CubeProgrammer.
You can choose 1, 2 or 3 and the he third level is the most detailed .
0693W00000GX7GuQAL.pngThen you can save it and send it to me.
Houda
Snara.21
Senior
0693W00000GX86gQAD.pngI am unable to select open file , if I se;ect no response, The same target board working fine in the IDE
Snara.21
Senior
Houda GHABRI
Hi @Snara.2​ ,
Ok to understand the issue please copy and send me all the data in Log TAB (highlighted by pink rectangle):
Houda
Snara.21
Senior
The same copied in the CubePrg.log file
