Visitor II
December 9, 2024
Arduine IDE cannot program through Cube Programmer
  • December 9, 2024
  • 3 replies
  • 901 views
I have installed STM32duino and using Arduino IDE to program STM32F407VG.  I have set the upload method to 'STM32CubeProgrammer(DFU). Arduino IDE fails to program the Board.  However when I download the .bin file created from Arduino IDE using the Cube Programmer, it works fine.  Can somebody help me to set the system so that I can directly program the board using the Arduin IDE.
Andrew Neil
You should probably ask this in the STM32duino forum - that's the official place for STM32duino support:
https://www.stm32duino.com/
Tesla DeLorean
Guru
December 9, 2024
>>I have set the upload method to 'STM32CubeProgrammer(DFU)..
Sounds like you haven't..
Perhaps you can use an ST-LINK/V2-1 or V3 that permits for a drag-n-drop of the .BIN into a USB MSC drive.
Problems with Arduino IDE, perhaps converse with Arduino, and their forum?
Selecting 'STM32CubeProgrammer(DFU)' requires you boot your board in dfu mode.
See the https://www.st.com/resource/en/application_note/an2606-stm32-microcontroller-system-memory-boot-mode-stmicroelectronics.pdf
to know how boot in the correct mode depending of your mcu.
https://github.com/stm32duino
