I am unable to establish a cubeprogrammer.
burak.colak
0693W00000ANgdkQAD.jpg0693W00000ANgdaQAD.jpgWhen the installation comes to the 7th step, it does not do anything, it wants me to exit the installation. When I looked at the directory where the program should be installed, there is no exe file.
Guru
EXEs are in the bin directory.
3 REPLIES 3
Guru
Perhaps there is an issue with administrative rights?
Have your IT staff install the application, or use "Run As Administrator" when installing.
Works here so assume something specific to your machine/configuration, which you'll need to get deeper into if you expect to find a solution, or report an issue.
burak.colak
thanks problem solved. Exe file is in the bin folder that I noticed. It worked when I turned it on.
