X-Cube-SMBUS middleware
‎2021-02-24 10:07 AM
I have downloaded the en.x-cube-smbus.zip package.
How can I added it to the stm32CubeIde as a middleware?
I have unzipped the file and moved the folder into STM32Cube/Repository/STM32Cube_FW_F3_V1.11.2/Middlewares but it is not seen by the stm32CubeIde application.
Thanks.
Pedro.
STM32CubeIDE
STM32CubeMX
‎2021-02-24 10:26 AM
Unfortunately such pack doesn't appear like a "pack". Such material is lacking .pdsc file (required to index pack content) at root means most probably not automation supported yet with (Help > Manage Embedded SW packages).
Consider it taking benefit of examples ("Projects" folder) and rely on copy / paste to add value to your own application.
By the way I would not recommend to "merge" such pack material with another delivery like F3 FW one or any other.
‎2021-02-24 10:29 AM
Thank you very much for your fast answer.
I will add the .c and .h files to my project core src and inc folders then.
