2025-04-22 3:08 AM
I created a project in CubeMX for STM32G0B1. I added ThreadX middleware. I chose "Add necessary library files as reference..." I generated a CMake project. It was good, it worked fine. After a few weeks of work and dozens of regenerations CubeMX leaves out ThreadX C sources from the generated CMakeLists.txt.
2025-07-08 5:59 AM
Hello @varghamp
The reported problem was solved, I suggest that you try using STM32CubeMX 6.15.0, which is currently available for download through this link: STM32CubeMX - STM32Cube initialization code generator - STMicroelectronics
BR,
Ghofrane
2025-04-22 3:14 AM
Hello @varghamp
First let me thank you for posting.
Could you please share your IOC in order to push further the investigation .
THX
Ghofrane
2025-04-28 4:11 AM
2025-05-06 2:27 AM
Hello @varghamp
Thank you for bringing this issue to our attention.
Issue has been raised to dev team for further investigation .
Internal ticket number 209114
I will keep you posted with updates.
THX
Ghofrane
2025-05-08 5:24 AM
2025-07-08 5:59 AM
Hello @varghamp
BR,
Ghofrane
