2022-05-25 8:00 AM
Hey,
I am trying to include X-CUBE-IRREMOTE for stm32g030f6p6 but it doesnt show up in software packs in cubeMX
if i try to manually install it it gives an error of invalid packet
2022-05-25 8:09 AM
The core of the question relates to the same cause as has been discussed before in the community. At that time it was about X-CUBE-EEPROM, but the principle is the same.
Does it answer your question?
/Peter
2022-05-25 8:09 AM
/Peter
2022-05-25 8:12 AM
hey @Peter BENSCH ,
Thanks for the promt reply.So i can use the drivers inside this X-CUBE-IRREMOTE and use them ?
2022-05-25 10:25 AM
