2022-05-20 12:14 AM
I try to set, using last version STM32CubeIDE, the ADC to get 8 analog inputs, using DMA, with permanent conversion.
Best regards,
2022-05-20 7:42 AM
Hello @lclor ,
Thanks for your feedback,
Could you please share a detailed scenario?, What is the CubeIDE version and did you open your project using the same version or did you migrate to a newer version.
Thanks,
Sara.
2022-05-24 11:47 PM
hello,
All my software and packages are up to date. And I didn't migrate from older version.
I have now again the Rank N°1, I have disabled all INXX, then enable again, and the Rank N°1 is now visible. I couln't give you detail scenario to make the rank N°1 not visible, because I made a lot of tries with ADC settings to try to make it running with DMA.
But I think there is an issue with STM32CubeIDE for this point.
Best regards,
Laurent
2022-06-02 8:38 AM
Hello @lclor ,
Did you by any chance imported a project on your STM32L151RETX using File -> Import Project?
If you didn't could you please share your ioc file to help me investigate more the issue?
Sara.
2022-06-02 11:19 PM
2022-06-02 11:23 PM
