using CUBEMX to generate makefile type project output (custom .h .c files)
Javier1
Principal
Is there a way to include in the makefile out custom .c .h , other than manually including each .c by hand in the makefile C_SOURCES?
we dont need to firmware by ourselves, lets talk
Pavel A.
Evangelist III
Yes. Since recent CubeMX versions can specify a post-generate command, this is how you can modify the generated output and add your files. Also see the CubeMX user guide UM1718 on the .extSettings file.
1 REPLY 1
Pavel A.
Evangelist III
