2023-12-13 06:02 AM - edited 2023-12-13 06:04 AM
Is there a way to include in the makefile out custom .c .h , other than manually including each .c by hand in the makefile C_SOURCES?
2023-12-13 08:43 AM - edited 2023-12-13 08:43 AM
Yes. Since recent CubeMX versions can specify a post-generate command, this is how you can modify the generated output and add your files. Also see the CubeMX user guide UM1718 on the .extSettings file.
