Uncluttering the Repository
‎2024-02-01 7:18 AM
My MX Repository has grown to more than 40 GB which is not exactly fun on the SSD of my MacBook. So I was wondering what made it so big.
There seem to be all the zip files of all installed firmware packages. Does CubeMX/CubeIDE ever use them again?
And what about the older revisions of the firmware packages? Is it safe to remove them?
STM32CubeMX
‎2024-02-01 7:37 AM
Yes to both. You should not need the ZIP files once they have been installed/unzipped. You can also uninstall older versions as long as you no longer have any projects that use them.
‎2024-02-01 7:37 AM
‎2024-02-01 7:53 AM
Thank you, that did cut it down to 1/3.
