Uncluttering the Repository
Guido Körber
My MX Repository has grown to more than 40 GB which is not exactly fun on the SSD of my MacBook. So I was wondering what made it so big.
There seem to be all the zip files of all installed firmware packages. Does CubeMX/CubeIDE ever use them again?
And what about the older revisions of the firmware packages? Is it safe to remove them?
Bob S
Principal
Yes to both.  You should not need the ZIP files once they have been installed/unzipped.  You can also uninstall older versions as long as you no longer have any projects that use them.
Bob S
Principal
Thank you, that did cut it down to 1/3.
