2021-04-27 05:02 AM
Examples from the relevant cube repository are working perfectly fine, i am able to burn, run and debug them. when i generate a project using CubeMX (while selecting the right board) i am not able to do so and get the following messsage:
Fatal error: Failed the search for probes, ensure that the USB drivers are installed.
please note that i have tried reinstalling CubeMX and downloading the H7 repository.
please advise on how to resolve this issue.
thanks.
2021-04-28 05:21 AM
Hello @yuri CH
Thank you for your post.
Would you mind please provide me with the exact steps to reproduce this issue ?
Thanks,
Mouadh
2021-04-28 07:27 AM
thanks for your response.
ofcourse.
step 5 fails and the IDE pops a message which says : Fatal error: Failed the search for probes, ensure that the USB drivers are installed. Session aborted!
