2021-04-24 11:09 AM
However I've installed V1.26.0 Pack before, but when I try to update it to 1.26.1 version i get the following error message during installing V1.26.1 Patch:
Problem during load of selected File
Missing dependency for this package.
-STM32Cube FW_F4 V1.26.0
2021-04-28 4:50 AM
Hello @RMoha.3
Thanks for raising the question,
It's a normal behavior, in fact, the latest CubeMX version is the 6.2.1 is compatible with the V1.26.0 Firmware version, the next release (6.3.0) will give you the access to use the V1.26.1.
Hope my answer helped you :) when your question is answered please close the topic by choosin Select as best, this will help other user find the answer faster.
Thanks for your contribution, Khouloud
2021-04-28 4:50 AM
Hello @RMoha.3
