trying to create a New CubeMX project...... downloading forever
Javier1
Principal
Is not a new installation of CubeMX v6.6.1, it has been working so far, untill today i try to File>New project.... and stays here forever
trying to unzip "cube-finder-db.zip"
we dont need to firmware by ourselves, lets talk
HBoss.1
Hi Javier
I had this problem today too, when I tried to create a new Project in STM32CubeIDE. I could solve it, by deleting the folder C:\Users\xxxx\.stmcufinder\plugins\mcufinder\mcu
I don't know, if this is the same location for CubeMX.
Good luck!
10 REPLIES 10
Javier1
Principal
Javier1
Principal
Similar question from @IMira.1​  a year ago.
I dont get the same error windos
https://community.st.com/s/question/0D53W000010Pe8jSAC/stm32cubemx-stm32f7-error-downloading-the-following-files-crdbfullzip-cannot-unzipped
trying out @VJADD.1​ answer
a year ago
Hello Saram.1
Delete the crdb_full.zip and close the STM IDE. Reopen the IDE and it will work fine. It works fine for me after deleting crdb_full.zip and reopening it.
Try it once.
Thank you.
located in
C:\Users\myuser\.stmcufinder\plugins\mcufinder\mcu\cs
 didnt work
Trying opening CubeMX with admin right , didnt work
HBoss.1
Hi Javier
Good luck!
This did work for me, thanks @HBoss.1​ .
Yes it was
It happened again today, i think i need to delete the same mcu folder every time i open subemx new project
apparently it happens randomly , i fix it removing the content off the /mcu folder every time..... not very nice
Probably the cause is antivirus or ransom protection software? Unfortunately I can not check this in my case, since I'm not allowed to switch it off ��
