trying to create a New CubeMX project...... downloading forever
2022-12-22 6:12 AM
Is not a new installation of CubeMX v6.6.1, it has been working so far, untill today i try to File>New project.... and stays here forever
trying to unzip "cube-finder-db.zip"
STM32CubeMX
2022-12-22 7:12 AM
Hi Javier
I had this problem today too, when I tried to create a new Project in STM32CubeIDE. I could solve it, by deleting the folder C:\Users\xxxx\.stmcufinder\plugins\mcufinder\mcu
I don't know, if this is the same location for CubeMX.
Good luck!
2022-12-22 6:18 AM
2022-12-22 6:24 AM
Similar question from @IMira.1 a year ago.
I dont get the same error windos
2022-12-22 6:25 AM
trying out @VJADD.1 answer
a year ago
Hello Saram.1
Delete the crdb_full.zip and close the STM IDE. Reopen the IDE and it will work fine. It works fine for me after deleting crdb_full.zip and reopening it.
Try it once.
Thank you.located in
C:\Users\myuser\.stmcufinder\plugins\mcufinder\mcu\cs
didnt work
2022-12-22 6:27 AM
Trying opening CubeMX with admin right , didnt work
2022-12-22 7:12 AM
Hi Javier
Good luck!
2022-12-22 11:32 PM
This did work for me, thanks @HBoss.1 .
Yes it was
2023-01-09 2:11 AM
It happened again today, i think i need to delete the same mcu folder every time i open subemx new project
2023-01-12 3:29 AM
apparently it happens randomly , i fix it removing the content off the /mcu folder every time..... not very nice
2023-01-12 4:02 AM
Probably the cause is antivirus or ransom protection software? Unfortunately I can not check this in my case, since I'm not allowed to switch it off :\
