2021-12-26 01:30 AM
ADC Trigger from Timer,DMA transmit ,and then Always Overrun Error, buffer address @0x30000000.Data can not be transferred to buffer correctly,ADC1 register DR is 0x801 while buffer is 0x01.
2021-12-26 07:51 AM
Show your code. How fast is TIM1? Are you transferring half words or bytes?
2021-12-29 11:20 PM
Hello @wjun.1 ,
Thanks for your feedback,
Could you please specify the CubeMX version and if possible, please share your .ioc file.
Sara.
2021-12-30 01:10 AM
Maybe take a look at this (wrong init order): https://community.st.com/s/question/0D53W00001EzCmCSAV/mxdmainit-order-in-the-mainc-file-generated-by-stm32cubemx-how-to-fix
