STM32H755bit getting stuck at WR_FLAG_VOSRDY
urbito
Senior
I have been working in a project with the mentioned MCU and by now i have been working it with SMPS_SUPPLY and VOS3 to work at 100Mhz Both CM7 and CM4.
By now days i need to boost it up to 400Mhz and 200Mhz, so i need to change from VOS3 to VOS1 but it is not available in my CUBEMx version 6.8.0 for all types of Supply i only have VOS3 and VOS2.
Not only that issue, if i for example try to use VOS2, i get stuck at:
while(!__HAL_PWR_GET_FLAG(PWR_FLAG_VOSRDY)) {} but when changing back to VOS3, it works fine.
I tryed VOS2 to change from 100Mhz to 150Mhz in both, but got the mentioned issue.
I found this thread: STM32H747 freezes waiting for VOSRDY - STMicroelectronics Community
Where some ppl said that is possible to not use this, but it feels strange...
Also found this one: STM32CubeMX 6.8.1 and STM32CubeIDE 1.12.1 released - STMicroelectronics Community
where it is fixed an issue with the version of Mx and IDE i am working with, but not for H7 Series But F7 serie.
Probably i am going to try it but i do not have much faith since is for F7 and not for H7. I would commend if i get any kind of result.
Hope to hear from you soon community :)
Greetings
urbito
Senior
Hello Belaid,
I have found one incongruent configuration due missunderstand between me and hw developer.
my hw have the circuit showed in green and i was configuring the sw to work with the one showed in red ( the stm32h745 dev board).
hope this helps anyone in future.
greetings
5 REPLIES 5
FBL
Hello @urbito,
Are you using customized board?  Which oscillator are you using?
I'm out of offce with limited access to my emails.
Happy New Year!
urbito
Senior
hello @FBL yes i am using a customized board with an external oscilator similar to the smt32h745 disco board.
FBL
Hello @urbito
Would you share a minimum project to reproduce the behavior in order to identify the root cause of the issue?
Happy New Year!
urbito
Senior
Hello Belaid,
greetings
FBL
Hi @urbito
Thank you for your feedback.
Happy New Year!
