STM32H753 + STPMS2L + DFSDM : PT100 example using STM32CubeMx
2021-09-19 9:43 AM
We're using STM32H753 (2 nos.) and STPMS2L in new product development. I'm looking for PT100 thermometer DFSDM example code generation using STM32CubeMx. Any example code available on PT100 voltage & current sensing on 2-channels?
- Labels:
DFSDM
STM32CubeMX
STM32H7 Series
2021-09-23 3:02 AM
Hello @S.Kamath ,
You'll probably want to review the DFSDM example within STM32CubeH7 MCU package:
\STM32Cube_FW_H7_V1.9.0\Projects\STM32H743I-EVAL\Examples\DFSDM\DFSDM_AudioRecord
This example shows how to use the DFSDM HAL API to perform stereo audio recording, and it can be a starting point for you to learn about DFSDM and to develop your own application.
Then, you can modify this working application depending on your needs.
This STM32H7 online training provides a support for Digital FIlter for SD Modulators Interface (DFSDM).
You can also refer to this AN4990 Application note Getting started with sigma-delta digital interface on applicable STM32 microcontrollers
Hope this helps you!
Imen
Imen
2021-09-24 8:07 AM
Couple of questions –
1. Is there any STM32CubeMx tutorials available on DFSDM?
2. Please find screenshot below for 2-wire PT100 thermometer measurements. Please let me know how to connect 4-wire PT100 thermometer?
[cid:image001.png@01D7B183.E065D080]
Best Regards,
Sadashiva Kamath
2021-10-22 11:25 PM
Thanks for details, this helps..!
Is there any STM32 microcontroller’s DFSDM example available for PT100 thermometer by using STM32CubeMx?
Best Regards,
Sadashiva Kamath
