STM32h745 ADC+DMA in cortex M4 continuous in Busy state
‎2023-02-27 9:20 PM
I am working on STM32h745 controller. In cortex M4 I enable two ADC3 channels. Read the ADC value using DMA method. Only one time I get the ADC value after that it shows busy. Also I changes the sampling time, but no effect. But that ADC3 channels properly work in cortex M7 using DMA method.
Can you please help me.
ADC
DMA
STM32CubeMX
STM32H7 Series
‎2023-02-28 6:08 AM
Hello @MDeva.1​,
Based on your configuration, you need to configure SRAM4 to store peripheral input/output data in D3 domain.
‎2023-02-28 8:41 PM
But how I can store in SRAM4, in Cortex M4 in flash.ld there is only one RAM
‎2023-03-01 8:06 AM
According to the reference manual, SRAM4 is the only RAM accessible by BDMA and ADC3.
I guess the linker for FLASH CM4 in IAR is correct. I will check the missing memory area in CM4 and get back to soon.
‎2023-03-01 8:50 PM
In cortex M7 I read the ADC3 is working properly but when I tried to CM4 it goes in busy state.
