2021-07-29 04:04 PM
Is there a way to go lower than 8kHz sampling Audio Frequency on I2S?
If so, how would I go about it manually adding in the code?
Thanks!
2021-07-29 06:19 PM
2021-07-29 04:45 PM
Try picking a close multiple and fiddle the values in the PLL or prescalers
2021-07-29 06:19 PM
There is 8-bits divider:
2021-07-29 06:20 PM
Thanks!
