STM32G4XX ADC: for LL driver, part of initialization hardcoded to ADC1
GLi.3
To reproduce: generate a project using ADC3 with the LL driver on STM32CubeMX 6.0.1.
Issue: regardless of which ADC is used, this shows up in MX_ADCx_Init():
  /* Disable ADC deep power down (enabled by default after reset state) */
  LL_ADC_DisableDeepPowerDown(ADC1);
  /* Enable ADC internal voltage regulator */
  LL_ADC_EnableInternalRegulator(ADC1);
The issue appears to stem from db/mcu/config/llConfig/ADC-STM32G4xx_LLConfigs.xml:
         <CallLibMethod Name="" Type="HardCode">
		<HardCode Text="
  #n#t/* Disable ADC deep power down (enabled by default after reset state) */
  #n#tLL_ADC_DisableDeepPowerDown(ADC1);
  #n#t/* Enable ADC internal voltage regulator */
  #n#tLL_ADC_EnableInternalRegulator(ADC1);
  #n#t/* Delay for ADC internal voltage regulator stabilization.                */
  #n#t/* Compute number of CPU cycles to wait for, from delay in us.            */
  #n#t/* Note: Variable divided by 2 to compensate partially                    */
  #n#t/*       CPU processing cycles (depends on compilation optimization).     */
  #n#t/* Note: If system core clock frequency is below 200kHz, wait time        */
  #n#t/*       is only a few CPU processing cycles.                             */
  #n#tuint32_t wait_loop_index;
  #n#twait_loop_index = ((LL_ADC_DELAY_INTERNAL_REGUL_STAB_US * (SystemCoreClock / (100000 * 2))) / 10);
  #n#twhile(wait_loop_index != 0)
  #n#t{
  #n#t#twait_loop_index--;
  #n#t}"
	</CallLibMethod>
It appears that ADC1 is hard-coded into the config XML file. I have to manually edit the code to ADC3 after generation to fix this issue.
Amel NASRI
Hi @GLi.3​ ,
Unfortunately your post was missed simply because it was misplaced under Bug-report topic. There are more opportunities to review it if you used topics STM32CubeMX and STM32G4.
Any way, for this one: I report it to our development team in order to take relevant corrective actions.
-Amel
Hello GLi.3,
Sorry for the inconvenience, it is a known issue and it has been already reported to STM32CubeMX development team to be fixed. The fix will be available in the future release. Thanks for your patience.
Khouloud.
