2024-10-25 1:38 AM
Steps.
2024-10-25 1:51 AM - edited 2025-03-06 3:46 AM
Hello @a_user
I'm investigating this issue internally and i will be back to you with the root cause of this. I've tested even with project for CubeIDE.
PS: Issue solved on the last release of the STM32CubeMX
Best Regards.
STTwo-32
2024-10-25 1:51 AM
Note. I originally saw this issue with version 6.12.0. Updating to 6.12.1 did not fix this issue.
Hello @a_user
Best Regards.
STTwo-32
