STM32CubeMX stuck at "Copying Library files"
uthraj
I am trying to "generate code" using an existing .ioc file. When I click on "generate code" , it is stuck. I am not able to close the window. I had to restart my laptop. I uninstalled and installed again. Tried the same process. But it didn't work. Need help.
5 REPLIES 5
Mahmoud Ben Romdhane
Hello @uthrajuthraj,
First thank you for posting and welcome to the ST Community.
Can you provide please the STM32CubeMx version which you are using.
Thanks.
Mahmoud.
It is the latest version - v6.9.2
Hello @uthraj ,
I have illustrated your request using STM32CubeMx 6.9.2 and the issue which you have mentioned was not reproduced. Can you provide please the basic characteristics of your computer.
Thanks.
Mahmoud.
Hello @uthraj,
Can you please provide the .log file.
Thanks.
Mahmoud.
uthraj
Hi @Mahmoud Ben Romdhane
I was able to sort out the issue. There was an "&" in my folder name that i was trying to save the file. Once i renamed the file i was able to generate the code. Thanks for the reply.
Thanks,
Uthra
