2023-10-26 09:27 AM
I am trying to "generate code" using an existing .ioc file. When I click on "generate code" , it is stuck. I am not able to close the window. I had to restart my laptop. I uninstalled and installed again. Tried the same process. But it didn't work. Need help.
2023-10-27 02:40 AM
Hello @uthrajuthraj,
First thank you for posting and welcome to the ST Community.
Can you provide please the STM32CubeMx version which you are using.
Thanks.
Mahmoud.
2023-10-27 04:47 AM
It is the latest version - v6.9.2
2023-10-27 08:00 AM - edited 2023-10-27 08:01 AM
Hello @uthraj ,
I have illustrated your request using STM32CubeMx 6.9.2 and the issue which you have mentioned was not reproduced. Can you provide please the basic characteristics of your computer.
Thanks.
Mahmoud.
2023-10-31 07:22 AM
2023-10-31 07:26 AM
I was able to sort out the issue. There was an "&" in my folder name that i was trying to save the file. Once i renamed the file i was able to generate the code. Thanks for the reply.
Thanks,
Uthra
