2021-03-12 02:38 AM
I am trying to configure the ADC of STM32L476RGTx to scan three channels, but STM32CubeMX only shows Disabled as an option to select for Scan Conversion Mode. I have also tried this with STM32L471VETx and the same problem exists.
Am I missing a prerequisite setting that needs to be enabled before Scan Conversion Mode can be enabled, or is this a problem with the device definition?
2021-03-12 02:52 AM
Hello @PPark.1
Thanks for your question,
Actually, the Scan Conversion mode can be enabled in case when the number of conversion is higher than 1, when you set it as 2 for example, the scan conversion will be automatically switched to Enabled.
Hope my answer helped you :) when your question is answered, please close this topic by choosing Select as Best. This will help other users find that answer faster.
Thanks for your contribution, Khouloud
2021-03-12 02:52 AM
Hello @PPark.1
2021-03-12 03:01 AM
Many thanks - as with so many things, it's obvious when you're told the answer!
2021-03-12 03:05 AM
I should probably add that I needed to Enable Regular Conversions before the 'number of conversions' option became visible.
