STM32CubeMX 6.8.1 and STM32CubeIDE 1.12.1 released
2023-04-27 9:48 AM
STM32CubeIDE/CLT 1.12.1 was released on st.com as well as an in-tool update patch.
Aligned with STM32CubeMX v6.8.1 that is available for download .
Caution: The in-tool update does not allow updating drivers and ST-LINK server tool. Full installer is required for this.
Main issues fixed in this patch:
This patch release fixes the issues related to the following cases:
STM32CubeIDE
- Incorrect permission of lib jspawnhelper in jre packaged in STM3CubeIDE.
- STM32CubeIDE does not launch with Linux Fedora
STM32CubeCLT
- Variable path is removed when CubeCLT is installed.
STM32CubeMX
- CubeMX project Cube IDE complication error on ETH
- Update to CubeMX 6.8 adds non-working VOSRDY flag check to SystemClock_Config() on STM32F7 using LL drivers.
- [X-CUBE-FREERTOS][v1.0.1] Can't select previous version with secure context
- [STM32CubeMX][MDMA] MDMA GUI crash causing issue with tool
Where do I obtain CubeIDE ,CLT 1.12.1 and CubeMX 6.8.1 ?
- For IDE 1.12.1 : https://www.st.com/stm32cubeide
- For CLT 1.12.1 : https://www.st.com/stm32cubeclt
- Or update your current installation of STM32CubeIDE using: Help > Check for updates
- updating STM32CubeIDE, the post-update restart fails. STM32CubeIDE must be restarted manually
Related threads
Click on cubeIDE 1.12 MDMA section sometime causes MX tab an undefined behaviour
- Labels:
STM32CubeIDE
STM32CubeMX
2023-04-27 10:36 AM
I'm seeing incorrect behavior in the Clock Configuration screen. It is flagging valid values as being out of range (STM32H743XIH6). Is anyone else seeing this? If I save and re-start CubeMX, I still see the same problem.
2023-04-27 10:44 AM
2023-04-27 1:45 PM
OK I found the reason -- I had silicon rev Y selected (has max core clock speed of 400 MHz) instead of V (supports max core clock speed of 480 MHz). It was non-obvious to me what the problem was, perhaps the reason can be displayed when you hover the mouse over the red boxes.
2023-05-02 2:34 AM
Hello @chriscole ,
For the STM32H743 , we have 3 revision :
Use silicon revision V devices to reach a maximum frequency of 480 MHz.
Foued
2023-05-09 8:04 AM
I'm seeing a problem that may be related to V1.12.1: when debugging on an STM32WLE5 using an STlink/V2, I often see the debugging session suddenly end when hitting a breakpoint. Restarting STM32CubeIDE makes the problem go away for some time, but it eventually happens again.
I don't think there's anything special about the breakpoint (it's in an ISR callback, but that shouldn't matter).
What logs might I collect next time it happens?
2023-05-16 5:26 AM
Does this fix the issue with the removed Middleware folder?https://community.st.com/s/question/0D53W00002ChskuSAB/update-to-stm32cubeide-1120-stm32cubemx-680-removes-middleware-folder-and-breaks-stl-build?t=1684239608514&searchQuery
