2020-11-03 02:44 AM
I was playing around a bit with the clocks.
I had it set up to run on 48MHz from MSI.
I then choose PLL on 64MHz but couldn't get the 1µs timer pulse I wanted (prescaler on 63 for TIM2 got me something about 1,178µs)
I then wanted to get back to MSI, but configuration tool found an issue with RCC
Flash latency is marked as a problem with 3 waitstates.
I can do nothing about it since its greyed out
any idea how I can get back to 48MHz MSI
cheers,
Bob
2020-11-09 08:32 AM
Hi @b.a.
Thanks for your feedback, issue confirmed and it will be fixed.
Best Regards,
Khouloud
2020-11-03 02:53 AM
Hi @b.a.
Could you please share your ioc file ?
Khouloud
2020-11-03 03:00 AM
2020-11-09 08:32 AM
Hi @b.a.
Best Regards,
Khouloud
2020-11-10 12:02 AM
Glad I could help improve the CubeIDE :)
