Input pin stm32g0 always remains low
Ali110
I am learning the stm32 using a stm32g070cbt6 micro controller with custom PCB with keil. When I add an external pull-up to the pa4 pin and use it as an input pin. Nevertheless, when I read the pin, the output is low always, even though on the hardware pin is high(3.3v). Yet I couldn't figure out why it happened. Please assist in finding this problem.
Thanks in advance.
#include "main.h"
uint16_t count =0;
int main(void)
HAL_Init();
SystemClock_Config();
RCC->IOPENR |= (1<<0);
GPIOA->MODER &= ~((1<<8) | (1<<9));
while (1)
if (!(GPIOA->IDR &(1<<4))) // if the pin is low count should increament
count++;
void SystemClock_Config(void)
HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1);
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
RCC_OscInitStruct.HSIState = RCC_HSI_ON;
RCC_OscInitStruct.HSIDiv = RCC_HSI_DIV1;
RCC_OscInitStruct.HSICalibrationValue = RCC_HSICALIBRATION_DEFAULT;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
RCC_OscInitStruct.PLL.PLLM = RCC_PLLM_DIV1;
RCC_OscInitStruct.PLL.PLLN = 9;
RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
RCC_OscInitStruct.PLL.PLLR = RCC_PLLR_DIV3;
Error_Handler();
|RCC_CLOCKTYPE_PCLK1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1) != HAL_OK)
Error_Handler();
4 REPLIES 4
gbm
Lead III
The pin is low - see IDR register. Try to declare count as volatile.
My STM32 stuff on github - compact USB device stack and more: https://github.com/gbm-ii/gbmUSBdevice
WojtekP1
from what i can understand is that you turn on clock for GPIO and then in just next instruction use GPIO registers. I would try adding something in between just to try.
second
this set up A4 to mode 00 which is input. all fine.
second - how do you check that count as it's infinite loop?
It's not set to volatile - so this loop may increment register, without even touching global variable.
Ali110
That's problem, i add 1k pull up at PA4 which makes this pin high, but actually it is low.
@Community member I appreciate your reply.
Purpose for count only:I want the count to increase only when a low pulse is detected at a pin.
The issue is with pin PA4 on port A. On the hardware side, I added a 1K pull-up resistor to make the pin high theoretically, but in practice, I get low. could propose anything
