In STM32CubeMX, when configuring the STM32H750VB MPU with more than 1 memory region and Generating Code, CubeMX gives a warning that some settings in the CORTEX_M7 module are missing or incorrect. I believe this is incorrect. Is this a bug in CubeMX?
2022-04-08 9:15 AM
I am trying to configure the Internal Flash (0x08000000, 128KB, cacheable), DTCM RAM (0x20000000, 128KB, non-cacheable), AXI SRAM (0x24000000, 512KB, cacheable), and QSPI (0x90000000, 4MB, cacheable).
There is no indication of what parameters might be missing or incorrect in the below warning.
CubeMX Warning:
- Main Config: These peripherals still have some not configured or wrong parameter values:
[CORTEX_M7]
STM32CubeMX
STM32H7 Series
2022-04-11 12:15 AM
Hello @DPade.1 ,
Thanks for your feedback,
This is a known issue and it is already reported to the dev team to be fixed. I will keep you posted.
Internal ticket number: 124250 (This is an internal tracking number and is not accessible or usable by customers).
If your issue is solved, please close this post by clicking the "Select as Best" button. This will help other members of the community find this response more quickly :)
Sara.
2022-04-08 11:11 AM
Can you attach the IOC? Typically there is a reason.
2022-04-08 11:17 AM
2022-04-11 12:15 AM
Hello @DPade.1 ,
Sara.
