How to change the Pull-up/Pull-down behavior in the stm32CubeMx Software.
FSchm.7
 I am using Linux Linux kubuntu 22.10 5.19.0-26-generic and when I click on the GPIO Pull-up/Pull-down column elements nothing happens except the color of the row changes.
Karl Yamashita
Lead III
You have to scroll down or drag the configuration window up a little bit to see the parameters
Tips and Tricks with TimerCallback https://www.youtube.com/@eebykarl
3 REPLIES 3
MM..1
Chief III
Click on System Core and GPIO.
Karl Yamashita
Lead III
FSchm.7
@Community member​  thanks a lot I just didn't see the scroll bar
