Hi, does anyone khnow why I can't set Continuous Conversion Mode to "Enable"? (I also use DMA with ADC)
SKiel.1
6 REPLIES 6
Javier1
Principal
doesnt it tell you aything helpful when you hover the mouse?
like this
Available for consulting/freelancing , hit me up in https://github.com/javiBajoCero
SKiel.1
It only tell that continuous mode and discontinuous mode can not be used at this same time (which is logical) however I can not change "Discontinuous Mode" to disable
Could you share your cubeMX file with us?
SKiel.1
RetroInTheShade
Hi, what version are you using? There is a bug in cubeIDE 1.9.0 for the G0. In our projects we override in the USER section of the initialisation function.
i opened your file, indeed there is something weird in cubeMX, it forces you to do scan->Discontinuous mode, in other boards stm32f072 of mine i dont have this issue.
Sorry i couldnt be of much help here
