[CubeMx 6.13.0 / STM32H7 Cube 1.12.1] CubeMx ADC configuration is not successsfully done in main.c
Yaël Boutreux
MCU used : STM32H753ZITx LQFP144
CubeMx version : 6.13.0
Situtation: I have a IOC file with some configurations on ADC1, like "Left Bit Shift" set to "4 bits shift" and "Conversion Data Management" to "DMA One Shot Mode".
Those modifications are not translated into the generation ADC init in main.c
I need to edit this by myself by calling
ADC_REG_InitStruct.DataTransferMode = LL_ADC_REG_DMA_TRANSFER_LIMITED;
ADC_InitStruct.LeftBitShift = LL_ADC_LEFT_BIT_SHIFT_4;
Hello @Yaël Boutreux ,
Let me thank you for reporting this issue.
I am escalating an internal ticket to the concerned team (ticket number: 202195)
Best Regards.
Mahmoud
6 REPLIES 6
Mahmoud Ben Romdhane
First let me thank you for posting and welcome to the ST Community.
For more investigation, I suggest please that you provide your Ioc.File.
Thanks.
Mahmoud
Hi @Mahmoud Ben Romdhane ,
Sure no problem, the corresponding .ioc file is attached to this message. :)
Thanks,
Yaël
Best Regards.
Mahmoud
Nicolas_B
Problem still present in 6.15.
Nicolas_B
My bad, it is fixed.
Hello @Nicolas_B ,
This issue is fixed.
I recommend that you use the last version of STM32CubeMX 6.15.
You can download it through this link :STM32CubeMX | Software - STMicroelectronics
Thanks.
Mahmoud
