Hello. How do I generate code by moving STM32 F0_FW v 1.11.0 back to STM32 F0_FW v 1.8.0? My current development environment is as follows. STM32 F0_FW v1.11.0, STM32CubeMX v5.4.0, STM32CubeIDE 1.1.0. Thank you in advance.
NR-A Comm
Khouloud ZEMMELI
​Hello @NR-A Comm​
For the moment it's not supported By CubeIDE (it can causes some error, so to avoid them it's better to use the last FW version).
otherwise, I will share your requet with team.
Thanks for your feedback,
Best Regards,
Khouloud
Khouloud ZEMMELI
​Hello @NR-A Comm​
Best Regards,
Khouloud
NR-A Comm
I understand.  Thank you.:D
Khouloud ZEMMELI
The FW version info into the ioc is always the one displayed into the "Firmware Package Name and Version" filed and not to the selected one when the "Use Default Firmware Location" is uncheked.
That means that, in that case, the used FW for the generated project is not the default one even if the FW version into the .ioc is always the latest one.
Best Regards,
Khouloud
