2024-09-12 04:06 PM
I've noticed that the generated CMake projects (specifically, in the toolchain gcc-arm-none-eabi.cmake file), a now-deprecated (since version 3.6!) macro is used https://cmake.org/cmake/help/latest/module/CMakeForceCompiler.html
I have to remove/comment out the use of these macros in my code due to it causing issues with other CMake libraries that I use in my project, which somewhat defeats the purpose of the CubeMX generated code to begin with.
Hopefully this is seen by the right person and this issue is addressed.
Thanks!
2024-09-13 06:18 AM - edited 2024-09-17 08:46 AM
Hello @drewhanshaw
Thank you for bringing this issue to our attention,
Issue escalated internally (Internal ticket number 191267). I will get back to you for any feedback.
KR,
Souhaib
Hello @drewhanshaw
KR,
Souhaib
