2020-01-04 09:58 PM
This error occurs in the compilation of the project generated by stm32ubemx. How can I solve it.thank you.
2020-01-05 05:39 AM
The core_cm4.h header file is in <your projectfolder>/Drivers/CMSIS/Include. Either that folder was removed/renamed or its not in the include folder list. Generate a new project from scratch and compare/copy files and folders as needed.
2020-01-05 08:01 AM
Include Paths not properly set up, or local project directory where files not completely copied
2024-11-27 10:57 PM
You can try to remove embedded software packages and reinstall. Change version 1.28.1 to 1.28.0 worked.
I might have broken packages too. Because I installed offline. I cannot blame version.
2024-11-28 12:00 AM
Hello @Fguof.1 ,
First let me thank you for posting and welcome to the ST Community.
In order to reproduce your request, I suggest please that you provide your Ioc.File.
Thanks.
Mahmoud
