Exclude files from update in cubemx
oeliks
Hi! I changed usb hid.c file not in user code. After I change something in cubemx and regenerate code this file is also changed to its oryginal form.
Is there a way to tell cubemx not to change this specyfic file?​
dbgarasiya
Senior II
according to my knowledge when you regenerate code all files will ramains as first as it is
3 REPLIES 3
dbgarasiya
Senior II
oeliks
Thanks, well I will change it manually then.​
dbgarasiya
Senior II
Best of luck @oeliks​
