2018-12-20 11:59 PM
Hello
To generate code cubemx try to donwlad stm32cube_fw_f7_V1140.zip without success.
Is it possible to have a link to download it in a different way ?
Thanks,
2018-12-21 5:29 AM
I send you the needed package to find a way out of that situation.
Kind regards,
Imen
2018-12-21 1:04 AM
https://www.st.com/en/embedded-software/stm32cubef7.html
There is download button at the bottom of the page.
2018-12-21 1:48 AM
Hello @chrisPyres66 ,
I have successfully download and install this package!
Did you tried to download from ST web site or STM32CubeMx tool ? Do you get an error message ?
Maybe you should check if you have space enough in your disk.
Kind Regards,
Imen
2018-12-21 2:09 AM
I try both methods but the download starts quickly, then slow and stops with "Error downloading the following files: stm32cube_fw_f7_v1140.zip" in cubemx
2018-12-21 2:09 AM
2018-12-21 5:13 AM
https://drive.google.com/open?id=1lYxP1gvB_a-8ynJ-KCszgBt2DWP4Snf1
2018-12-21 5:29 AM
