DevEbox in CUBE IDE
hardw0rk3r
Hello! I'm new to the Cube IDE and i want to work with the Chinese board DevEbox with STM32H743VIT6 on it. Before i worked with Arduino Framework where i tested the sd card, ethernet and other basic functions. I wonder, if it and how it possible to use the same DevEbox in Cube IDE as IOC file for example. Should i configure it all by myself or maybe someone has already made and shared it? I would be grateful for any solution.
0 REPLIES 0
