CubeMX v6.12 generate wrong makefile project
Soraka
I use CubeMX + VSCode + arm-gcc + makefile to compile embedded programs. CubeMX v6.12 create wrong stm32fxxx_flash.ld file. Some words like "RAM" is lacked. And CubeMX v6.11 and CubeMX v6.10 is right.
SofLit
Hello @Soraka and welcome to the community,
Try the latest version 6.13 ..
PS:
5 REPLIES 5
SofLit
PS:
Thanks. I saw related answer in STM32CubeMX errata 6.12.x.
Did you test 6.13 and check if the behavior still there?
PS:
toroid
Had the same problem with a project using H7 series. I can confirm that updating CubeMX from 6.12 to 6.13 fixed the issue.
