CubeMX does not export ADC functions
Tobe
Senior III
When i export the pins from Cube, it does so, except for the ADC pins.
Its CubeIMX 6.8.0
6 REPLIES 6
Ghofrane GSOURI
Hello @Tobe
1- Could you please  explain what do you mean by "export ".
2- Could you please try to use the latest version of CubeMX 6.10.0
It will be helpful if you tell  the exact scenario in order to reproduce your issue
Thx
Ghofrane
1: I "explain" with a picture. In the datasheet it is called "Additional functions"
2: No i will not test your new version.
AScha.3
Chief III
just --- this "export pins" : what is it useful for ? and where import then ?
Hello again @Tobe
Thank you for your contributions and for your detailed explanations,
I confirm the issue on my side, it has been reported to STM32CubeMX development team .
Internal ticket number: 167358(This is an internal tracking number and is not accessible or usable by customers).
Thx
Ghofrane
Hello @AScha.3
Export pinout with Alternate functions :Generates pin configuration as a .csv text file including alternate
functions information, this file can be (later) imported into a board layout tool.
Thx
Ghofrane
Thx    , @Ghofrane GSOURI .
